3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Problems when exporting dwg to 3ds max 2017
6 REPLIES 6
892 Views, 6 Replies
Hello
When exporting dvg in the 3ds max 2017, elements from the drawing (ellipse) are not imported. This drawing in the 3ds max 2014, is imported without problems. How to solve this problem?
3ds max 2017
3ds max 2014
6 REPLIES 6
in 2014, save
in 2017 open file just saved in 2014, save, done.
(NKP)
Alfred.DeFlaminis
Hello @Anonymous and welcome to the community,
It does seem like there is a problem here.  Posting both settings was a good move.  I need to log this most likely, would it be possible to share the splines with me so I can investigate and log this?  It seems like the 2nd fishlike shape is being cut out of the first, which is clearly not supposed to happen.  I can create a private folder for you if you need to keep this private, and I'm happy to do so.
Best Regards,
Alfred.DeFlaminis
Hello @Anonymous,
I just wanted to follow up here, is it possible to share the file?
Best Regards,
in reply to: Alfred.DeFlaminis
Yes, I can send a drawing, which email should I send?
Alfred.DeFlaminis
Hello @Anonymous,
I have set up a private folder for you if you'd like to upload your files there. You should get an email about it shortly, and if you don't see it please check your SPAM folder. These files are private and will not be shared with anyone but yourself and the support staff. Please let me know if you have any questions. Please use at least an 8 character password or the Box account may not work properly.  Thanks!
Best Regards,
Alfred.DeFlaminis
Hello @Anonymous,
I just wanted to follow up here, any progress on this issue?
Best Regards,
