Problem with Ivy Generator Plugin in 3ds max 2018
Message 1 of 23
Hello, I discovered an amazing free plugin for 3ds max which allows you to grow ivy on every surface.
Unfortunately the author stopped to develop his plugin. He even removed the download link from his website but he also states that everybody is allows to share any remaining copy of his plugin.
According to the author the last supported version is 3ds max 2018 but when I try to install it i get an error message (message in attachment). In 3ds max 2017 it works fine.
I included the plugin in the attachments. You only have to select your 3ds max version and copy gw_Ivy.dlo to your 3ds max-plugins folder. Is there any way to get this plugin running in 3ds max 2018?
Replies (22)
Message 2 of 23
I attached the plugin for the 2018 version. I grapped it directly from the plugin folder of my installation, so it should work.
You probably placed the 2017 version in the plugin folder.
The thing with plugins in 3dsmax is: If there`s a SDK-break in a release, a given plugin needs to be recompiled for this specific version.
You can look up this requirements by checking this page of the SDK help:
http://help.autodesk.com/view/3DSMAX/2018/ENU/?guid=__developer_about_the_3ds_max_sdk_sdk_requiremen...
Message 3 of 23
Thank you so much Sir!!! But where did you get this file or did you recompile it by yourself? I tried again every file and non of them worked, except yours.
Message 4 of 23
To be honest, i have no idea where i got it from. Also i can`t find the original downloaded .zip file anymore.
Well, with the next 3dsmax SDK-break it will be gone anyway, Given the tone of his 'good bye' message, he won`t share the source for sure.
Message 5 of 23
pproestos
thanksssssssssssssssssssssss
Heart Heart Heart
Message 6 of 23
You can also find it at the bottom of the page here:
http://www.guruware.at/main/ivy/index.html
EDIT:  Sorry, that WAS the link for the Generator.  Apparently, not anymore.
Message 7 of 23
It`s dead. The author decided to no longer update this FREE plugin after some moron donated only 0.05 euros for it. Which the author thought was an insult. I have to agree with him, sadly this is what the 'community' have become.I mean seriously,wtf? 0.05 euros?
Message 8 of 23
Hi every one i'm doing a project and i need some help, i need ivy generator plug in for 3ds max 2018
i tried this guruware but i can not download the zip file,
thank you
Message 9 of 23
3ds max 2018 ivy generator not working plz help me
Message 10 of 23
same
Message 11 of 23
JezEmin
He does issue the 2018 version as I, and others I know, also have it.
I'm not able to go to his website now but what I did (and my peers) was pay him a decent amount and he does send you the version.
I'd suggest anything between $20 -> $50 is what I and others have 'donated'.
I cannot release it here, because then you'd be getting it for free which is not only a bigger insult to the guy, but is also theft.
3d rendering services
Asus X299-SAGE, 7980xe @ 4000mhz, Corsair Hydro H150i Pro,
1Tb Samsung M.2, 128Gb Corsair LPX DDR4,
2 x Nvidia RTX 3090 FE,
3DS Max 2023.1 (3DS Max 2022.3, 3DS Max 2021.3 as backup)
Windows 10 Pro.
Message 12 of 23
I donated $5, rip
Message 13 of 23
Well, if he is offering it free and that is not OK for him, why he simply doesn't sell it?
Message 14 of 23
The Ivy generator for Max is a handy interface of a pre-existing program done by another programmer. This can explain why the creator of the interface for Max doesn't sell it as the core program is not from him.
The original programmer, Thomas Luft,  has not deleted his page.  You can keep using it free of charge as long you export the model as OBJ. This is the place to download the program and a tutorial, in this case for photoshop but the funtionality is the same as long you have an OBJ.
Obviously it is more convenient integrated with Max but it is always good to know there are alternatives.
http://ivy-generator.com/
Message 15 of 23
Great,
Thank you it's working perfectly.
Message 16 of 23
Thank you so much.  Worked perfectly.
Message 17 of 23
pproestos
Any chance to make this plugin working with max 2019?
Message 18 of 23
guruware
just a wild guess...
someone has to compile that for 2019
Message 19 of 23
JezEmin
@guruware
Maybe that person could be you 🙂
Just a wild guess 🙂
Windows 10 Pro.
Message 20 of 23
@guruware Thank's in first for your work.
I love to use your plugin.
But i don't know how to "compile for 2019".
Could i learn to do it?
Or some one could help us?
Thank you in advance!
Sylvain.
