Announcements
Problem to export in OBJ from 3ds max 2020.2
marc.pat
marc.pat
Hello I just open a support ticket today from my subcription.
I write if Know other people have the same problem.
When export in obj from 3ds max 2020.2 or 2019.3 the mesh is broken.
in 3ds max 2016 the export is ok.
The problem is with obj, with FBX the export work well.
The video is in Italian but you can see tre problem, present for me with many 3d model
I use win 10 Pro.
best regards.
miledrizk
In the Obj Import Options dialog, Normals group,
Choose the option "From SM Group",
The second option "Auto Smooth" works also, but first, try the above.
miledrizk@gmail.com
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
marc.pat
Thank you for the tips miledrizk
I try it.. some part is better but other is similar..
So for a moment I need export from 3ds max 2016.
best regards.
marc.pat
I see the video for support Autodesk and for us work fine, but in my case work only if save obj from FBX and import with sm group, as you see at the end on the video.
best regards. mak21
marc.pat
Thank you to support Autodesk for test my file
https://knowledge.autodesk.com/community/screencast/7518ba60-2f23-45ef-9ef4-2250c2e283c5?fbclid=IwAR...
in the video all work weel.... i can't Undertsand why on my computer is not like this.
I'am with win 10 pro, amd 1800 X.
For a moment I continue export my obj from 3ds max 2016, or export obj from fbx file in 3ds max 2020.2
best regards.
Mak21
