problem moving objects
Hi! I have imported a model created in autocad.
The problem is that when I select all the model and try to move It, the elements move in different way like in the photo. Someone knows how to solve this problem? I want to move the model cause it's under the base plane and it's difficult to work in that position.
Francisco_Penaloza
The best way to import CAD files in to Max is using the link function, after that you can merge that file if you like.
To resolve your issue, select all objects and click the broken chain icon to unlink the mesh for the coordinate dummy. You may want to click a few times 😉
After that you could do a reset Xform and you should be ready to go.
I solved the problem Francisco!!! Really thank you!! 🙂
Francisco_Penaloza
Great, Glade to help.
