Preset configuration
Hello, I have the next doubt:
I have 3dstudio 2017 version. I made a "preset" where I customized all the parameters that i wanted.
Each time I open "Render Setup" I get the preset that the program brings up by default and i have to open the drop-down list and search for mine.
Is there any way to always open the one I personalized directly? Thanks in advance! Regards!
darawork
This is just a guess... because I can't test it myself (I don't have permission to delete files from the Program Files folder on my PC), but have you tried deleting the presets you don't need from C:\Program Files\Autodesk\3ds Max 2017\renderpresets ?
You can also switch the Render Preset by using MAXscript:
rpsFilePath = "X:\\projects\presets\[Insert PreSet Name Here].rps"
if doesFileExist rpsFilePath then
	renderPresets.LoadAll 0 rpsFilePath
else
	messagebox "The RPS file can't be located" title:""
Just put your .RPS into the correct folder (and change the information in line 1 above, to match it).
When this code is run it wll change the preset in the Render Setup window (Even though it will say "Preset: No preset selected") it has changed.
You can test the code first (In the Scripting menu -> New script) and if it works, then save it as an .ms file and put it into your C:\Program Files\Autodesk\3ds Max 2016\scripts\Startup folder. It will run every time 3DSMax starts.
Darawork
AutoDesk User
Windows 11, 3DS Max 2026, Revit 2026, AutoCad 2026, Dell Precision 7875 nVidia - Quadro RTX4000 ATA - AMD Ryzen Threadripper PRO 7965WX 24-Cores - 128GB RAM
Thank you! 😉
