Preference Setting Issue
deepakaspam
deepakaspam
HI
I'm using 3DS Max 2022.
I have an issue with preference setting menu.
Whenever i change any option under preference settings it works, but when i restart 3ds max it doesn't work. I need to save the same setting again and again. ( Like : if i deselect object outline option and when i restart max it shows automatically selected. )
I'm tried of doing this thing all the time.
Please help
MaxBlum
Hi
Do you have Save UI Configuration on Exit option checked  in Preferences dialog?
deepakaspam
Thanks for your reply...
Yes i have already checked the option, but it stills happens the error😣
DanielCantin
Hi @deepakaspam
I suspect you have V-ray installed, this should be resolved in 3ds Max 2022.1, a script has also been shared to fix it for 2022.0: 3ds max 2022 fail to save settings
Please let us know if this resolve your issue, thanks for reaching out.
Daniel Cantin
QA Manager, 3ds Max, Maya
Entertainment Creation Products, ECP
deepakaspam
Hi @DanielCantin @MaxBlum
thanks for your reply, but it still not working out.
I'm still facing the same issue again after try the max script solution from your side.
Can you have any other solution?
I'm using 3DS Max 2022, Corona 7, V-ray 5.1 & Windows 11.
DanielCantin
Hi @deepakaspam,
Here a few more suggestions:
  1. confirm if it is an issue with V-Ray by uninstalling it
  2. update V-Ray to the latest update
  3. the script shared will only work once if not put in the startup script folder, if it worked once but not after, it is important to place it there so it is run in every session
  4. update you 3ds max to 2022.1 or later versions
  5. restore your user setting if case they are corrupted, the thing to do when 3ds Max start behaving strangely: How to reset 3ds Max user preference settings back to default
I hope this help, please let us know how it goes.
Daniel Cantin
Diffus3d
On my Windows 10 machine I have to run 3dsmax as administrator to setup menus and things or it won't save.  So I run as admin and get everything how I like it, then run normally form there.    If you run as admin, do the changes stick?
Best Regards,
