Polygon wire frame display abnormal intermittent in Perspective
The 3dmax14-18 version has an entity + wire frame showing that the line frame displays abnormal intermittently in the perspective. If it is modeling, it affects the editing vertex and line segment. When I edit part of the line or vertex to adjust the part, I find that the line box looks close to the object gradually, and it looks intermittent, and is gradually approaching the surface of the object. Actually, the line box is not displayed. It is not known which of the display line box components in the software problem. But I found that when the perspective map was changed into an orthogonal view, the rear line box displayed very normal. There was nothing wrong with my drawing, but the orthogonal view was normal, but after adjusting the model or rotation, it was not as good as the perspective operation. If I have the problem of graphics card, it seems to be intermittent in the orthogonal view, but the result is different from the perspective entity line box, and it is very normal. Follow up I will upload the picture. My card is seven GTX780 3G 385 bit wide memory rainbow. The WIN7 64 - bit system CPU:I7 4790K graphics card displays normal in both the movie and the PS, only the 3DMAX all version perspective line segments show the abnormal impact of the drawing. So I hope that relevant personnel of software technology and Industry Zone Chinese Autodesk friends to solve my problem, resolve the troubles in my heart. I would like to thank all of you first.
To tell the truth, Chinese forum reply too little, and later found themselves is the object size too big system size mm, although the objects in the object coordinate origin but beyond the highest object in the real world, so to maximize the window operation easily broken or cause line intermittently, after I put down after the object object display does not appear very normal and this method can solve the problem, should thank the foreign community Autodesk technical support Mr. Alfred.DeFlaminis answer may be described in the system unit solution users are similar to problems with me a little, I used in my results on a test was effective in me. So pay tribute to Mr. Alfred.DeFlaminis.
