Announcements
Polygon Bridge shortcut
Is there a way to assign a shortcut to Bridge when in Edit Poly mode? Just for Bridge not for Bridge settings.
brentscannell
Hi @Anonymous
Is "Bridge" not doing what you expect it to do when you assign it to a hotkey?
Please note, any commands that are bolded in this list represent actions that can be activate in two ways: A single, short key press and lift (time defined by the "delay to override" setting) will activate Bridge. If you hold it down for longer that the the time defined, it will only be active for as long as you're holding the assigned key.
