Please, help me. software problem error
unreal7204
unreal7204
Community Visitor
Community Visitor
I was unwrapping the uv with max. Press the pelt map button and the editer window will pop up. Press the start relax button there and the screen will suddenly shut down. It's the same no matter how many times I do it. I've tried updating AMD and adding the max program to the window firewall as it says on Autodesk, and I've tried how it appears on the internet, but it still has an error. Please let me know what the method is. help me Please...what should I do....?
RobH2
It sounds like there are errors in the mesh file you are working with. Have you tired to rebuild it? Have you tried the same unwrapping on another mesh object? If it works on a simple mesh like a generic sphere then it means that Max is not misbehaving.
Have you run 'STL Check' on your mesh, and if there are errors, fixed them until there are "none" and then tried the 'Pelt' again?
Rob Holmes
3ds Max (2023-2026), V-Ray 7, Ryzen 9 9950X3D Processor, DDR5 128MB, Gigabyte Aorus X870E Master motherboard, Sabrent Rocket NVMe Gen5 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
