this is the srror code i keep getting
mentalray has encountered a fatal error and the application will now shut down. The error is: DB 6.0 fatal 041008: attempt to access null DB tag.
this is the first project i have used with the distributed bucket rendering. all renders just fine if i have no rpc in my scene. as soon as i turn on the rpc, then hit render, i get the fatal error.
any suggestions will be welcomed.
thank you;
Herb
