3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Pivot problem when reopening the file
3 REPLIES 3
490 Views, 3 Replies
Hi everyone, i had an issue with the pivot point in 3ds max, I'm making a car and i want to open the doors, every door is a group, so to make the opening correctly, I've changed the pivot point.
The rotation works fine but when I close the file (saving it off course) and i open the file again, the pivot of the doors are aligned again to the center, and i need them to stay where i put them. How can i solve this problem? Thanks in advance.
Tags (2)
3 REPLIES 3
Steve_Curley
Do you really need the Groups? Try un-grouping them, create a Dummy and position it where you want the Pivot to be, Select and Link all the previously grouped components to the dummy. Groups have been known to not "play ball" when animating. And make absolutely certain none of the components have been Scaled (at the object level) - that will almost certainly mess up animations.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
in reply to: Steve_Curley
OK i will try and i'll let you know, thanks for the tip
Thanks for the tip Steve, it worked perfectly, i have never worked with dummys before, i learnt something new today Smiley Very Happy thank you.
