Issue: Pivot point stopped following objects in 3ds Max
When the pivot point no longer follows objects during transform, this is usually caused by a mode or state being unintentionally enabled, but in some cases it can also be a temporary system or session glitch.
Common things to check first
Hierarchy Panel → Affect Object Only
This is the most common cause.
Check:
Command Panel → Hierarchy → Pivot
Make sure “Affect Object Only” is OFF.
When this option is ON, the pivot moves independently from the object, which feels like it’s “not following.”
Working Pivot Mode
Sometimes the Working Pivot gets enabled.
Check the toolbar:
Look for “Use Working Pivot”
Make sure it is disabled
Shortcut to toggle it:
Alt + X (depending on key mapping)
Reference Coordinate System
Verify that you are not stuck in:
Parent
Local
View
Screen
Switch back to:
World
When none of the above works (your case)
If the issue happens:
With all objects
Even after restarting 3ds Max
And only fixes itself after a full system reboot
Then this is not user error.
Likely cause:
Temporary sync issue between Windows 11 and 3ds Max
Memory or viewport state corruption
Long-running Max session instability
This does happen, especially in heavy scenes.
Proven fixes for this situation
✔ Fully shut down Windows (not just restart Max)
✔ Reopen 3ds Max and load the scene fresh
✔ Avoid long Max sessions without restart
✔ Save incremental versions frequently
Many professionals experience:
“Max works perfectly after a fresh launch, but degrades over time.”
That’s unfortunately normal behavior.
Professional tip
If you notice certain actions:
Always crash Max
Only work correctly right after startup
Then:
Do those actions immediately after launching Max
Or isolate them in a clean scene and merge later
That’s a smart adaptation, not bad workflow.
Summary
First check Affect Object Only
Then check Working Pivot
If neither applies and reboot fixes it → system/session issue
No scene corruption involved
