Pivot point stopped following objects
meah2016
meah2016
I must have hit some button accidentally because my pivot point no longer follows objects i transform. I have to continually right click and choose to reset the pivot point. Please let me know what button i should check to get things back to normal.
Thanks.
MartinBeh
Maybe you have enabled Hierarchy Panel > Affect object only?
See https://help.autodesk.com/view/3DSMAX/2026/ENU/?guid=GUID-6872F014-4785-43D9-A83B-C774507907B3
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
meah2016
Heh, that would have been the easy solution, but it was for all objects every time. I wondered if maybe the scene had been corrupted, as happens sometimes, but that wasn't it. Shutting down and reopening Max didn't work. What did work was shutting the computer down and opening it the following day. Suddenly for no reason things were back to normal. I'm guessing it was a combination of Windows 11 and Max not synching up correctly. I have had other instances of Max simply getting tired and not performing correctly. Shutting it down and restarting usually fixes that. But taking a day to fix is a new item. There are other things that i do in Max that will crash it every time unless i do them immediately after starting Max up and opening the scene. I just adapt. No big deal.
MartinBeh
That sounds weird. I do not see why anything (except drivers) should be different between shutting down 3ds Max and rebooting the OS.
Are you using a roaming Windows profile?
meah2016
I have only my personal experience to go by. If something works, like shutting down and restarting then i accept that solution. It's the same solution IT people have been using for decades when computers error out....and it works so often that no one questions it. As to your question about using a roaming windows profile, i have no idea what that is so i can't answer that.
khalidbenahmadou
Issue: Pivot point stopped following objects in 3ds Max
When the pivot point no longer follows objects during transform, this is usually caused by a mode or state being unintentionally enabled, but in some cases it can also be a temporary system or session glitch.
Common things to check first
Hierarchy Panel → Affect Object Only
This is the most common cause.
Check:
Command Panel → Hierarchy → Pivot
Make sure “Affect Object Only” is OFF.
When this option is ON, the pivot moves independently from the object, which feels like it’s “not following.”
Working Pivot Mode
Sometimes the Working Pivot gets enabled.
Check the toolbar:
Look for “Use Working Pivot”
Make sure it is disabled
Shortcut to toggle it:
Alt + X (depending on key mapping)
Reference Coordinate System
Verify that you are not stuck in:
Parent
Local
View
Screen
Switch back to:
World
When none of the above works (your case)
If the issue happens:
With all objects
Even after restarting 3ds Max
And only fixes itself after a full system reboot
Then this is not user error.
Likely cause:
Temporary sync issue between Windows 11 and 3ds Max
Memory or viewport state corruption
Long-running Max session instability
This does happen, especially in heavy scenes.
Proven fixes for this situation
✔ Fully shut down Windows (not just restart Max)
✔ Reopen 3ds Max and load the scene fresh
✔ Avoid long Max sessions without restart
✔ Save incremental versions frequently
Many professionals experience:
“Max works perfectly after a fresh launch, but degrades over time.”
That’s unfortunately normal behavior.
Professional tip
If you notice certain actions:
Always crash Max
Only work correctly right after startup
Then:
Do those actions immediately after launching Max
Or isolate them in a clean scene and merge later
That’s a smart adaptation, not bad workflow.
Summary
First check Affect Object Only
Then check Working Pivot
If neither applies and reboot fixes it → system/session issue
No scene corruption involved
