3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Physique wont merge
11 REPLIES 11
Message 1 of 12
426 Views, 11 Replies
Physique wont merge
Hi, I hope someone will be able to help me please.
I'm using Max 2010 Design Extension and am trying to merge a biped with physique from Max 9 which I downloaded from Turboquid into a 2010 file.
The biped part of the person merges but none of the physique part does.
I've tried searching the forum and have ensured the units match etc. Has anyone got any ideas?
I don't usually work with charcter animation so am a bit out of my depth.
Thanks very much in advance.
Sarah
Physique wont merge
Sarah
11 REPLIES 11
Message 2 of 12
Is the original file OK, if you Open it, not merge it?
Message 3 of 12
Hi, yes the original file works fine, the physique is all there and the movement works fine etc. When I come to merge into another file, the physique items don't even show in the list of items to merge.
Thanks very much, Sarah
Message 4 of 12
Hi again, I thought it might help if I attached the max file in question.
Please can someone using Max 2010 try merging it into another file and see how they get on with it?
Edit: hmmmmm, cant seem to get it to upload, if you think you can help I'll email the file to you? Thanks
m15.zip
m15.zip
Message 5 of 12
Steve_Curley
Steve_Curley
Edit your post, attach the max scene which MUST be ZIPPED (not .rar or anything else) then Submit - do NOT preview.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Max 2016 (SP1/EXT1)
Message 6 of 12
Thanks very much, I previewed it!
Message 7 of 12
Steve_Curley
Steve_Curley
Either I'm being rather dim today, or it just doesn't work. At all. Ever.
Just tried merging (in Max 9) a character from one of the standard Max tutorials, following the instructions in the help - and it doesn't work.
Either I'm missing something or there's a problem here.
Can anyone get a biped + physique to merge in any version of Max?
Max 2016 (SP1/EXT1)
Max 2016 (SP1/EXT1)
Message 8 of 12
in reply to: Steve_Curley
Not working for me either. But I'm just going to try something...
Message 9 of 12
This is really odd. I've tried all sorts of things, and nothing works. Using Physique to Skin Utillity didn't do it.
It must be something with this file, other files with Physique merge OK.
Message 10 of 12
Thanks to both of you for trying. I'll go back to Turbosquid and ask the author of the file to amend it for me - looks like it's an issue with the original file. Thanks again, Sarah
Message 11 of 12
Steve_Curley
Steve_Curley
I must be having a bad day then because I couldn't get it to work at all. Maybe I was just picking bad example files...
Max 2016 (SP1/EXT1)
Max 2016 (SP1/EXT1)
Message 12 of 12
I merged the old SK_BABY.MAX from early CS. The Physique skin came in OK. With this file I only get his hat, which doesn't have physique, and the biped.
I've re-saved the file in 2010, converted the physique to Skin, converted the mesh to Epoly and re-applied the skin. None of this makes any difference, I'm stumped.
