Physical Material Presets are looking at wrong paths for bitmaps.
Message 1 of 1
I believe that I have set project paths correctly, because whenever I add a "General/Bitmap" it shows correct folder and I can chose from preinstalled bitmaps. But when I try use a Physical Material Preset which uses a bitmap file, it always look for default 3ds Max Projects root folder for the required bitmap file. It doesn't look for the location which I have set on "Configurate Project Paths".
What should I do to make Physical Material Presets to look at correct bitmap paths?
Replies (0)
