Can someone tell me what is the best software to create photo spheres?
Solved by blakestone. Go to Solution.
Hello @Anonymous,
Is a photo sphere like a panoramic image? You can use 3ds Max for that out of 3d but it's more of a cube map. @blakestone's is a better solution.
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
Mental Ray has a built-in "Camera > Lens Filter > Wraparound" which will produce a spherical map of your scene.
This can be used to create spherical panorama or environment map etc.
This video demonstrates how to set this up: https://youtu.be/EhUI8Stz7po
