- Mute
- Permalink
- Report
I rarely use particles but I'm following a tutorial from Max 2012. I'm watching the author interactively drag settings for the wind he has set up on a plane to vary the shape of some drips. It's real time and fluid when he drags and you can watch the changes occur on the model smoothly.
When I do the same thing, following the tutorial exactly in Max 2022 (as well as Max 2020 and 2021), it's painful. And I have a pretty powerful machine, I'm sure much more powerful than anything available in 2012. When I make a change, all viewports flash black and it takes about 5 seconds for the adjustment update to occur. Actually, I can't drag the values as that creates chaos. I have to input values or things just grind to a halt.
Is this normal these days for PF Source work or am I having some issues? I've run benchmarks on my machine and it's performing perfectly in all the parameters tested.
Thoughts?
Rob Holmes
3ds Max (2023-2026), V-Ray 7, Ryzen 9 9950X3D Processor, DDR5 128MB, Gigabyte Aorus X870E Master motherboard, Sabrent Rocket NVMe Gen5 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
