Persistent UPITOKEN & CADSETTINGSPATH errors
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When I close my 3d max (3d max 2012 design on windows 10 64bit) I repeatedly get two popups with the following errors:
"An Autodesk product failed to send the required value for UPITOKEN. The error report sent to Autodesk may be incomplete"
and
"An Autodesk product failed to send the required value for CADSETTINGSPATH. The error report sent to Autodesk may be incomplete"
I googled the above and only getting results with UPITOKEN. The solution to that problem seems to uninstall, reboot and do a clean install of the software DWG TrueView. Which I did, but alas it didn't solve the issue.
Anything other solutions would be greatly appreciated.
ps: another thing I notice is that the icon of the Error Report is the Trueview icon. And in the error report itself it mentions that 3d max 2014 64 bits is the max version which is incorrect. I will also attach the dumpdata for further info.
