Organic complex shape with wind driven facade
creative_team_r8
Message 1 of 9
creative_team_r8
Community Visitor
Community Visitor
Greeting everyone ,
Can someone please help me to model this wind driven facade in organic shape ?
I have attached a picture for a reference of the wind driven facade .
Regard,
Replies (8)
Message 2 of 9
MartinBeh
Looks like a good candidate for the Array modifier (or for Particle Flow if you want maximum flexibility, at the price of a somewhat high setup cost).
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
Message 3 of 9
A娘
you can use datachannel with 2027.1 and higher version
example files
https://cganimator.com/3dsmax-2017-1-datachannel-modifier-samples/
https://cganimator.com/3dsmax-datachannel-modifier-sample-pack-2/
Sequinss from pack 1 has the same usage
Message 4 of 9
maroom.r8
it didn' work .At first the shape was plane then edite poly then falloff from the soft selection .now
when I try the this it did't work. ☹️
Message 5 of 9
MartinBeh
Do you only need to model this (without animation), or do you also need to animate this, as if the wind is moving the individual elements?
Message 6 of 9
maroom.r8
I'm trying to do both a render shot and animation .
I have attached a link below for the effect  .
https://pin.it/3It3UbJcf
Message 7 of 9
MartinBeh
Maybe a bit like this?
(view in My Videos)
Message 8 of 9
maroom.r8
Yes how did you do it  ?
does this work even if my shape is?
Message 9 of 9
MartinBeh
The previous example was using MAXScript to distribute the elements as well as animate their rotation based on a noise driven by their world position.
Here is a test using TyFlow with Birth Surface and PhysX Bind:
(view in My Videos)
