My material editor keeps hanging when I open it, possibly because of a bitmap that's no longer on my network. I hangs before I'm able to disable material sample rendering and I can't switch to compact material editor either.
Is there a way of closing material libraries before opening SME, or to open it in a 'safe mode' as such, without the libraries, or without sample rendering?
Solved by jon.bell. Go to Solution.
Hi TB_Rio,
Thanks for your question. Some suggestions:
Please let us know if this helps, and we hope to hear from you soon!
Hello @TB_RIO ,
Just checking to see if your problem has been solved. Have you tried the above suggestions from @jon.bell and did you have any success? If you find the suggestions helpful, please click on the "Accept as Solution" button in his reply so this helps other users in the community find the solution too. Thanks!
