Opening fan door animation - pivot points
office6PUWT
office6PUWT
To create an animation of this door opening I need to rotate each of these 12 fan blades from (-55 degs (1st blade) in increments of 5 degs each up to 0 deg (12th blade)) around their own individual pivot points located at 12 different points along a central axis running through the centre of all of the bottom holes. How do I do this please?
all best
Luke
Diffus3d
Hello @office6PUWT ,
I don't see anything in that image (invalid file), but the array tool seems like a likely candidate.
Best Regards,
RobH2
Like Alfred says, the Array Tool is probably going to be helpful for you. Sometimes there is no "automatic" way to do what you want. You may just need to animate them one at a time until it works like you want it to. Often, simple sounding animations can be quite time consuming to get set up properly. It looks like (I was able to see the image) you already have them rotated by 5° each and that you've mostly solved it.
Rob Holmes
3ds Max (2023-2026), V-Ray 7, Ryzen 9 9950X3D Processor, DDR5 128MB, Gigabyte Aorus X870E Master motherboard, Sabrent Rocket NVMe Gen5 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
leeminardi
Post the file and the desired  before and after picture would help to understand what you want to do.
If I understand your goal correctly you could use a wire parameter.  I assume you want to rotate the top blade (#1) from -55 to 0 about it x axis and have the other blades follow such that they all wind up at 0 degree.  Wire the x rotation of #2 to #1 so that its angle is 11/12 of blade #1's rotation.  #3 would be 10/12 of #1, etc.
lee.minardi
