Opacity maps does NOT show when converting to Stl
I have a problem: i used opacity maps in my 3ds max project file instead of modeling the shapes. and now i need to 3d print the model and the opacity map is not visible in the converted stl model. what should i do? please help me!
Thanks in Advance
hi, I think the stl format does not support maps but just geometry
So what formats support maps so that i can 3d print the model? any ideas? Thanks
PROH
I don't think any format will support 3D print of opacity maps. You'll have to model it.
___________________________________________________________________________________________________
3dsMax 4.2 to 2018
AutoCAD 2000 to 2018
Infrastructure Design Suite Premium 2012 to 2018
are there any other maps for that that works with 3d printing? maybe
displacement or any other sulotion
No
+1 with @PROH
leeminardi
If you used opacity maps to give the appearance of holes try using Boolean substract to create real holes.
lee.minardi
