.Obj export problem with normals.
piotrek.waciega
piotrek.waciega
I have problem with exporting to .obj and I can't find answer in another post.  I have to export my 3d models created in 3ds max to another application usign .obj extension. I do it from few years, It working well in 3ds max 2017, but in next versions, is problem with normals exporting. I have installed old 2017 max only to exporting this models. I attached screen, it schow how my 3d model look after export and imort to 3ds max. Anyone can help me? Thanks
10DSpace
@piotrek.waciega
Looks to be a smoothing group and/or normals issue relating to .obj export/import which is discussed here:
https://forums.autodesk.com/t5/3ds-max-forum/help-3ds-max-2017-obj-export-smoothing-groups/td-p/6914...
Checkout out post 11 in the above thread which discusses  the normals from SM group setting in the .obj importer and see if that works for you.
piotrek.waciega
@10DSpace thak You for Your answer,
I just checked proposed method.  When I set import normals from smoothing groups models work well. But it don't solve my problem, because my client's aplication don't have import options. Adding edit normals modifier and make explicit causes another problems.
