Not having Delete command on the keyboard
I'm a MAC user and I'm using 3ds max via bootcamp. Sşnce I don't have a delete command on my keyboard I cannot directly delete anything that I'm modeling on max. I've tried to change the shortcuts but it doesn't work. It says it has been changed but nothing happens when I'm trying to delete something. Is there any other suggestions for this issue? How can I fix it? I am using 2018 btw.
Reassigning the Hotkey should work. At least here under 3dsmax2020.
Did you use the correct shortcut (Delete Objects) ?
Are you using the latest release of 2018, which is 2018.4 ?
Hey there
Thanks for the answer. It did work. There is one more thing that I wanted to learn. Is it possible to assign backspace as delete command?
@Anonymous wrote:
Hey there
No, i don`t think so.
