3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Noise Map vs Arnold
28 REPLIES 28
Message 1 of 29
quinnredshift
1356 Views, 28 Replies
Noise Map vs Arnold
For some reason, I cannot get Noise maps to work with Arnold; everything with a Noise map renders white (for that particular Mat ID).
These are the standard, basic, general Noise maps, mind you.
I tried using the Arnold-specific Noise maps but I simply cannot reproduce what I'm trying to do with the legacy Noise map because there are way too many settings and some settings that seem to be completely missing, and it's all a big mess.
Why aren't Noise maps working, and how can I make them work?
28 REPLIES 28
Message 21 of 29
I'm not just thinking about now.
I'm thinking about the future, too.
Cuz if I give one example of something specific I'm trying to do, I'll just be back here later asking how to do the same kind of thing with different parameters when I need to do something similar but which seems unavailable (yet existed and was easily found in previous versions of MAX).
So when I say I want to do "everything", I'm mean because I'm going to be using everything that legacy maps are able to do, but which have been deprecated in current versions of MAX.
But in particular, the "Gradient Type" and "Coordinates" panel are the biggest issues.
I can't seem to get the same level of control out of Arnold maps. What used to take tweaking one variable seems to now involve all kinds of gymnastic and kludging to get results which used to be extraordinarily simple.
I'm butting up against a lot of changes to how things worked in MAX 2013 (which was the last version I used until now), here, guys; please be patient with me.
Message 22 of 29
wernienst
in reply to: quinnredshift
I've just found that there is no need for UVM Map Modifiers (except activating 'Generate Mapping Coordinates') on objects. By putting a UV Transform between Ramp Rgb and the surface shader you have even more control...
Message 23 of 29
wernienst
in reply to: wernienst
btw, the sphere on the left is a spherified cube...
Message 24 of 29
quinnredshift
So, wait...UV Transform is basically the Coordinates panel, but separated from the original map (where, in previous versions, it was integrated into most maps)?
Message 25 of 29
wernienst
That's correct. The advantage is, you can use (almost) every other map/shader as input to the parameters. The disadvantage is, there may be a lot of try & error (and frustration). Aside from that, the 3dsmax part of the Arnold manual gives only sparse information, e.g. the Ramp Rgb has no own entry. So it's a good idea to also consult the general part of the manual.
Message 26 of 29
wernienst
and doing the tutorials 🙂
Message 27 of 29
quinnredshift
I mean, you might be right about the tutorials.
Cuz this is such a radical change from what I'm used to, and I wasn't expecting to need to do tutorials! Heh. 😋
Message 28 of 29
wernienst
Btw, there is a new MaxtoA version out, 5.6.2.0. Generally, they are updating it more frequently than 3dsmax itself.
Message 29 of 29
quinnredshift
I think I saw a notification about that.
As long as I can render using the GPU, I'm a happy camper. That's really my only goal, here, or I'd be using a lot more legacy maps (and, if I'm perfectly honest with my dumb self, whinging less).
