Network render only after restarting backburner on the render machine
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Never had problems with backburner before 3dsMAX 2016. Went back to 2015 all works fine. Again work with 2016 and every time I want to render I have to restart backburner. I downloaded the latest backburner from the download site (which shows the same version number as the previous one - 16.0.0.0). Now my workflow is to shut down backburner server and restart it and then transmit the job. If I don´t restart I get the world famous message " 109 - the pipe has ended". As far as I know it is not only a backburner message. Windows and some programs seems to produce the same error message. I have edited the settings of backburner server to the specific IP-adress of the manager.
Wenn I transmit a render job the screen of the server machine at first shows some different flickering windows on different spaces of the screen. Finally the rendering window pops up. But if I didn´t restart beackburner server before trasmitting the job the rendering window disappears after a tenth of a second and later the error message appears in the backburner window. This behaviour led me to the conclusion, that this is not an network setup error. What can I do. I have no time to install 2017 because of the customization work during working on projects. Does anybody have a solution for my problem? Also I tried to find out how to setup backburner as a service. I read a lot about it on different pages but no good tutorial how to set up it. Does anybody a good source for this? And do you also have some other flickering windows on the render machine screen before the rendering window comes up?
Workstation: Ryzen 9 5950x@ 4,20GHz 64 GB RAM, Nvidia RTX 4090, Win10 Prof.
Rendernode: AMD Threadripper 2990wx@ 3,20 GHz 64 GB RAM, Win 10 Prof.
Autodesk Building Design Suite Premium 2025, VRay 7, ForestPack, RailClone, RichDirt, KStudio ProjectManager....
