3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
My Camera in the Dope Sheet has Roll Angle instead of Rotation
4 REPLIES 4
bast0424
529 Views, 4 Replies
Hi. I am trying to copy the Position & Rotation from one camera to the other. But the other camera (which is a CoronaCam/VrayPhysicalCam) doesen't have it. Here's the kicker though: It has worked before, with the very same cameras and then it suddenly doesen't. I don't know what keeps changing and it's super annoying.
Does anyone know if theres a way to FORCE Max to only use Rotation unless otherwise specified?
PS: I attached an image so you can get an idea of what I'm talking about. Hope you can help 🙂
Regards
Bastian
4 REPLIES 4
10DSpace
in reply to: bast0424
@bast0424
You are trying to match a free camera with the Corona camera.  Not an expert on Corona, but try changing Corona cam to Free type if it's an option in Corona cam rollout.
bast0424
in reply to: 10DSpace
I probably forgot to mention I am trying to copy the keyframes from the Cinemotion Cam onto the Corona Camera. I cant copy Rotation onto Roll Angle so I need to somehow get the Rotation back. I've done it before, but I don't know how 🙂
10DSpace
@bast0424
A "Target"  camera has a roll angle parameter.
A Free Camera has the x,y,z Rotation you are looking for.
So you need to change the Corona camera to a Free Camera type like in the images above.   I do not know Corona or have access to it, but I have to believe it has a similar option as a dropdown in the rollout to change it from a "Target" Type to a "Free" Type.  If you do that you should get the X,Y,Z Rotation you are looking for.
bast0424
The solution was to turn off the Target of my CoronaCam.
Thank you 🙂
Technology Administrators
