MXP File Issues
MXP File Issues
bzubrick
MXP File Issues
bzubrick
I am running into issues with the MXP file in 2019. I will go through the process of reloading almost 400 directories and when I close out of 3ds Max and open it back up it will only load part of what I had added previouslythere should be 378 directoriesthere should be 378 directoriesupon reload 3ds Max only loads 79 Directoriesupon reload 3ds Max only loads 79 Directories
daniel
a better workflow is to have everything correctly pathed in the asset tracker. If you keep pulling assets from files that don't have correct paths you will always be reliant on those external paths. I abandoned the approach you are using a few years ago.  If you need to relink a file use the "Relink Bitmaps" script. works well
ddesmarais
We have been having this issue for years and there has been no fix in sight. No solution from Autodesk either on this.
