mP Glue does not bind with Other Events Particles.
Hello. How do I configure mP Glue to make bindings between my Event 005 and Event 016?
Bindings do happen when I enable Current Event Particles or when I highlight the current event in the Other Events Particles list. So it is not a matter of distance settings and such.
I have tried using two mP Glue tests that point at each other, but that doesn't work so it's disabled in Event 016.
Never mind, it works if you place the mP Glue ABOVE the mP World operator.
Maybe add this to the Knowledge Network?
https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/3DSMa...
Nope, never mind. The big particles did snap to the other ones, but they are not glued. And it generates an error in the listener window saying mP Glue should be below mP World.
Turn off mP World gravity and use a separate gravity-force as a work around?
