when moving an object from one file to another the dimensions might be different , how to i access again the width height and length window for that particular object or others present in the file ?
I just wanted to see if you ever solved your dimensions issue? I'm assuming you have as it's been a few weeks now. Just checking.
Rob Holmes
------------------------------------------------------------------------------------------------------------------------------------------hello
no i never got a reply on how to resize an object once you do the initial sizes . there is no way of resizing and changing the measures and dimensions again , i have to redo the object which is not normal . i only have the scale button which distorts my objects when they are to become very small for the simulator . any help would be appreciated .
