Move and Rotation tools not working in 3ds Max 2017
Hi, I use 3DS Max 2017 and while I was working on my project in my laptop until both move and rotation tools stopped working.
I checked the Selection Lock and it was off, Pivot are still the same, I even reinstalled the whole program (updated it too) and I even checked the preference and they're all normal. I checked with the other 3DS Max available at my University and it works fine and I'm pretty stumped as to why this happens to me.
I have recorded and uploaded the video of me struggling with the move and rotation tool. Scale is fine, it's just those two tools.
Also i have this problem sometimes,in using 3ds Max 2014.I restart 3ds max and use it.But now i'm using 3ds max 2018 without this problem.(sorry for my english).
It's okay. I restarted my 3DS Max to see if it changes and nope, it didn't. I'm still having the issue with move and rotation tools
miledrizk
Select the object, go to Motion Panel, In the Assign Controllers rollout check
If the Position has a Position: XYZ controller assigned to it, if not, click the Assign Controller
Button and from the list choose Position: XYZ. Now if you see that the Position: XYZ is already
Assigned but you cannot move, click the + sign to expand and, individually click the X, Y and Z positions,
And for each one click the assign controller button and choose Bezier Float.
For the Rotation now, if the controller assigned is not Euler XYZ, click the assign controller button and
Choose it from the list. And like before, if you see that it's already assigned, expand the list and for each element
Assign the Bezier Float
[email protected]
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
I did as you were told and it worked! Thank you so much!
i still cant move it whyy??
