3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Model is not displaying properly if I applied shell modifier in 3DS MAX:
2 REPLIES 2
277 Views, 2 Replies
The model is fine without applying shell but whenever I applied shell the interior look model topology distorted why is that? As far I know the shell make the inner or outer copy of that model which means it does not should be display like that
https://imgur.com/HyqFIxH
Also, If I remove vertical edges then there is some problem inside the shell model. It is hard to explain so here is the link for clarification:
https://imgur.com/1eHGo95
2 REPLIES 2
Brandon568
Post your max file so i can take a look.
in reply to: Brandon568
@Brandon568
Here you go. The file has been shared.
