I had a problem back in February after an update to Max2021 whereby opening scenes with Xrefs caused a crash every time. I eventually fixed it by reverting to an older version of MaxtoA (backed up from 4.3.1.0 to 4.0.6.3) - as far as I can remember I did this just by dragging an old version into the Plugins folder. Since then no problem, now running 4.2.1.4. Today I installed Max2022 and lo and behold the same problem has appeared with the added bonus of an Error code 127 when launching. I have followed the steps in this article https://tinyurl.com/5fxudjfr to try to fix the Error 127 but to no avail. I also tried updating MaxtoA in my 2021 installation and the same problem recurred. In the article it suggests that old versions of MaxtoA may cause the problem but I notice that if I uninstall all instances through the Windows control panel an old version mysteriously loads when I restart Max2021. How can I thoroughly remove all old versions of MaxtoA and if I do will it fix the problem of Xref scenes crashing?
Thanks, William.
