MAXScript Rollout Handler Exception:
Message 1 of 9
Hi guys,
I am stuck with what I am doing in Civil View in 3ds Max Design when I encountered this MaxScript Error. Can you please help me on what to do?
-- Runtime error: Not creatable: Civil_View_Path___Surface_ConstraintMatrix3Controller <<
-- Runtime error: Not creatable: Civil_View_Swept_Object <<
Replies (8)
Message 2 of 9
CAMedeck
I've had this error pop up before.  The way I fixed it was to go to this folder:
C:\Users\USERNAME\AppData\Local\Autodesk\3dsMaxDesign\2014 - 64bit\ENU\en-US\plugcfg
and delete the CivilView.ini file.  You'll have to restart Max and re-initialize Civil View.  Worked for me.
Chris Medeck
Message 3 of 9
Thank you very much sir! It works for me too.
Message 4 of 9
hi , you're right , i deleted the civil view.ini and it works with me
Message 5 of 9
I HAVE APROBLEM LIKE THAT AND I CAN`T FIX  WHEN I WAS TRYING TO INSTALL TRACK SCRIPTIMG_0015[1].jpg
Message 6 of 9
stanleykipchumba54
Community Visitor
Community Visitor
got this message ,while creating animation using OPS editor,
"MAXScript Rollout Handler Exception:
-- Runtime error: Not creatable: Civil_View_Path___Surface_ConstraintMatrix3Controller "
after deleting, CivilView.cfg and restarted, it worked for me.Thank You so much.
Message 7 of 9
thank u so much
Message 8 of 9
egokbayrak245
I deleted it as you said. it worked for me but the extension of the file appeared as ".cfg"
Message 9 of 9
michael.walker
Community Visitor
Community Visitor
It doesnt work for me. Still have the same error, even after deleting the civil_view file.
It says Runtime error: Key index out of range in getKeyTime: 1
