3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
32 BIT STUDENT version
27 REPLIES 27
Message 1 of 28
54765 Views, 27 Replies
sir are there any student version or free trails for 32 bit version.plz plz plz help me.
27 REPLIES 27
Message 2 of 28
lynn_zhang
Hi @Anonymous Welcome to Autodesk Community!
All recent versions of 3ds Max (2016/2015/2014) require 64 bit. The latest version for 32 bit is 3ds Max 2013. You can download the free trial of both 3ds Max 2013 & 2012 from our Virtual Agent (click on Download Links, choose product and version). However only 2016/2015/2014 are available for student version which are for 64 bit.
Lynn Zhang
Message 3 of 28
hi..good night.i am want to dowload 3 ds max,becouse i am need to my school
Message 4 of 28
DarrenP
whats your question?
DarrenP
Message 5 of 28
Hello And what is the product key for 3d max 2013
Message 6 of 28
camilo.lemos
Hi @Anonymous and welcome to the Autodesk Community!
Here is a list of all 2013 product keys.
I hope this helps!
Camilo Lemos
Message 7 of 28
Tofiq1234
Please I want maya 2016 32bit software
Message 8 of 28
DarrenP
in reply to: Tofiq1234
not available anymore
system requirements are here: https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/System-re...
64 Bit only
DarrenP
Message 9 of 28
in reply to: camilo.lemos
Hi, I donwload the 3DS Max 2013 because my Windows is 32 bit. Now I need serial number to activate the program. How I can get it?
In my user area I only can get the 2016 version.
Thanks.
Message 10 of 28
Hi, I need Maya 2013. So, I'm Downloading it by Virtual Agent. But now I will need its product key and Serial Number. From where I can find?
Message 11 of 28
jasmin.gonzalez
@Anonymous Hello, if you are a student you will need to register here to download version 2013.
Jasmin Gonzalez
Message 12 of 28
jasmin.gonzalez
Hi @Anonymous as mentioned before, if you are a student you will need to register in our Education Community here.
We only have 2013 available for students.
Jasmin Gonzalez
Message 13 of 28
i want the version 32 bit free ...help me please
Message 14 of 28
read the whole thread again
Message 15 of 28
I have read the whole thread and read the links and I do not see any option to download 2013 32bit.
Message 16 of 28
May somebody explain it to me: first, why couldn't I use 64-bit 3Ds max on my 32-bit Windows? second, why is it impossible to get the corresponding version newer then 1013?
I realize the first question looks silly, though I have it installed (this morning), and it seems to work. Should I expect the badnews later?
Message 17 of 28
dgorsman
Your questions a are little jumbled, but I'll try to answer.
Software isn't written from the ground-up anymore, its written using building blocks created by others (in this case, mostly Microsoft).  This allows for rapidly creating and easily maintaining very complex applications.  These building blocks are 64-bit, so the operating system must also be 64-bit to support them.  Those building blocks use 64-bit math and pointers, allowing access to larger amounts of memory than with a 32-bit application.  You cannot install 64-bit software on a 32-bit OS, so I'm assuming your comment is on installing a 32-bit program on a 64-bit system.  In some cases this will work, but with a memory-hungry program like 3DSMAX you want to access more than 4 GB of RAM.
You can get newer versions than the 2013 release; I'm assuming you mean you cannot get access to the 2013 or older releases.  Developers regularly retire older software as it won't run reliably on newer hardware and operating systems.  That includes not only the program itself but also supporting features like licensing.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 18 of 28
in reply to: dgorsman
"You cannot install 64-bit software on a 32-bit OS, so I'm assuming your comment is on installing a 32-bit program on a 64-bit system."
Believe me, my 5-year old laptop is 32-bit. For about two years I've been using 64-bit photoshop (successfully), until recently changed it to 32.
Ok, it's not the point. I think I should unveil my purpose of installing 3ds max, if I want to get your help. I need it for Skyrim modding, for modifying armor and other models. So I have to install a corresponding plugin, that is a nif plugin. And I need all that stuff to be adoptable to my 32-bit OS. What I've gotten yesterday after installation the 2016 64-bit 3Ds Max and 2016-nif-plugins-3.8.0-a3 is a blank (no textures) model in a viewport. Concerning I am absolutely new to 3Ds max, I might miss something, maybe some settings. Or it is a deadend with 2016 versions, and I should came down to 2012. Have you ever bumped into similar problems? On Nexus I've been told here on Autodesk.com I can get some help Cat Embarassed
Message 19 of 28
read the system requirements again it is clearly stated 64 bit windows
https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/System...
since you are having trouble with a 3rd party add in you need to contact the developer of that add in not here
