MaxLiquids default water particles don't fill a container
Message 1 of 18
Hey there,
I have this issue where I cannot get the default water settings in MaxFluids to fill a container or basically spread like spilled water.  In max, scene scale as cm, maxfluids as 1 unit = 1 cm, I build a container 20cm x 20cm and extrude it down so it's a pot basically.  I put the default 5cm emitter over the top, load up the default water settings, set the container as the collider and sim.  The particles do not fill as I expect and when I emit just over the side expecting the particles to spread like water they disappear.
I have changed the Adpativity setting to .8 and the min to 100 and max to 1500 per a couple of tutorials I have seen to try and assist.
Is there anyone that can suggest what I may be doing wrong as to not achieve what should be a fundamental when it comes to this sort of thing.
Thanks heaps for any assistance.
S.
Replies (17)
Message 2 of 18
madsd
Can you upload this scene? It may be as simple as fixing up your collision mesh, but a scene would be helpful.
Message 3 of 18
ok let me get something over to you soon. I am just going to create it from scratch again to make sure I haven't butchered something in the setup.
Message 4 of 18
ok false alarm, I am not actually sure what I did wrong previously but it fills and overflows perfectly. The only thing I changed was the Thickness to 0.0 for the collision objects and viscosity to 0.1.. but the rest is absolute stock standard water preset settings. Anyway.. will put this down to severe user error somewhere.
Message 5 of 18
madsd
Awesome, there is nothing better than revisiting and solving stuff 🙂
Message 6 of 18
a general question.. do you build everything and sim in CM? is there any instance where you would change that, even for a larger scale sim? There are not a lot of MaxFluids tuts around so I am looking at Maya BiFrost tutorials, but of course in Maya BiFrost is stuck in metres, regardless of what units you use in the app. I try to stick to real world everything in cm.. dunno if I am making a meal of bigger sims by doing this.
Message 7 of 18
madsd
Depends, personally I got max at cm pr default so I tend to block everything out from that starting point, but regardling liquids I always tend to favor eyeballing it in addition, you may need to do a big waterfall from the tip of a needle, or a rain drop smashing into a planet destroying it, so I'd say, eyeball comes first over anything 🙂
Message 8 of 18
Here is an example of the particles just disappearing.  As far as I am concerned there should be a wide spread of particles.  They just disappear not long after hitting the surface.
I have messed around with erosion and adaptivity and the like.. can't make it work properly.
S.
Message 9 of 18
madsd
Will check your file and likely fix it in the morning.
Message 10 of 18
cheers dude, appreciate the time.
S.
Message 11 of 18
madsd
Hey, so I checked your file.
The box drops into the container and makes a splash, the splashes goes outside the container, I am not seing anything "disapearing" what should I look for, as I would say that what I see is what I would expect.
Can you clarify which part you would expect to not disapear so I can debug it further.
Message 12 of 18
hmmm,  I don't get the dispersion across the ground object like you are getting there.  The particles were not even really reaching the side to over flow.
I will run the sim again and see, is your scene scale the same as what was in the file.  i.e. 1 unit = 1cm?
Message 13 of 18
madsd
yes, just aligned to your scale and simmed
Message 14 of 18
What do you mean aligned to my scale.  Sorry I am just trying to pinpoint every little change to ensure I am working to the best way I can with liquids.
I know I am on the right track, just not quite seeing what I think I should be seeing 🙂
Message 15 of 18
madsd
Sorry, I accepted the scale the file came with, so whatever it was, I
always work in cm, so if the file came with that, I didnt have to
adjust, just mentioned that I worked under same scale as your file came
with.
Message 16 of 18
For example here is mine 7 frames in.. the water that pours over is completely different to how yours looks in the upload you did.
Message 17 of 18
re-run it again (I changed the voxel size in the first pic).
This is me opening the scene and clicking sim..  exactly what I sent in this thread - this is my frame 12
I am baffled.
Message 18 of 18
Just to round this off.. when I unticked the box to use CM and changed to meters I get something close to what you uploaded.  I changed the setting to .5 and it is really close now.
Which makes NO sense at all, the scene units are cm, it was modelled in cm, but when I run the sim at .5 meters I get the result I was expecting.......
