max temp folder on C: movable?
Hello;
We are experiencing full disks at work due to IT giving our C: size 100Gb to install only software.
ofc this leads to problems and we created a second 😧 disk to dump our temp files from photoshop and such.
There is a problem with Max though, I tried moving our "standard project folder" from max where all our autosaves go and such, too the 😧
but the following folder is dumping up to 10Gb of dumpage while we work and I'm wondering if it's possible to reconfigure this folders position to the 😧 as well?
C:\USER\AppData\Local\Autodesk\3dsMaxDesign\2015 - 64bit\ENU\temp
this folder path contains alot of junk that loads while working and unloads when we close max.
Is this configurable?
It's a bunch of .tmp files (see screenshot)
grts
Stefan_L
Did you try Customize/Configure System Paths?
Stefan
i7-2600 @ 3,4GHz, 32GB Ram,
512+128GB SSDs + 2x500GB HD
GeForce GTX 980 Ti 6GB + GTX 980 4GB
latest Driver (almost always)
Win7ProX64 SP1
DarrenP
the previous post will allow you to change this path
DarrenP
CAMedeck
You can disable the bitmap pager in 3ds Max.  It's on by default.
You could also edit your 3dsmax.ini file to choose a different location.  Just open the INI file in Notepad and search for TEMP, it should come up right away.  Then type in the new location there.
Chris Medeck
thanks guys, appreciated
blinddel
Choose in max: Customize\Configure System Paths - then modify ))
