Hello everyone,
my goal is to create splashes like the one in the attached picture, is this possible with Max Fluid?
It's mainly about the surface tension with the thick edges.
The screenshots are mainly from animations created with Houdini, Houdini solves it internally without an extra plugin.
It is not possible with Phoenix Fd, which was confirmed to me again in the Facebook group. RealFlow can also do this with an extra plugin, but it hasn't been updated for 5 years and it's too expensive.
Once again, it's about the surface tension with the thicker edges.
Maybe someone has an idea.
If it cannot be solved directly with Max Fluid, could it be solved with a script? If so, who can do this? 😄
Thanks in advance.
