Hey,
We're experiencing Max files that won't open in less then 3 houres...
For the last 2 to 3 weeks we've been looking into the network and the network (in)stability cause we assumed that the networks' speed is the bottleneck.
Now when googling "Max files open very slow" i've come across this:
and this:
http://area.autodesk.com/blogs/maxstation/n170-filebloat-removing-lots-of-empty-retimers
My question is simple: do these bugs still exist in Max 2015? At this time it's 14:00 and the file has been opening since 12:00, if it ever opens I will check if it helps to run this "Clear-Retimer" script...
Can someone explain to me what a Retimer is and if I should be careful with deleting all of them?
It's a max-file with about 16 Xrefs in it, it's an urban-scene with alot of work put into it and everything has become slow.
The renders take ages, the opening of the file takes ages, and the settings are really the same as they've always been and I do think we're using settings that are optimal.
We use "compress on save" to limit the file size and now it's about 100Mb with about 11 Xrefs who are each roughly 50Mb each
In total we could say it's about 1Gb file size uncompressed if every Xref would be merged.
hello
one of my max file is taking very long time to open
although it's not taking time in saving
file size is 9.46 mb
i tried all attached scripts but no use
on using
clean retimer it's giving msg: --Unknown property: "numRetimers" in undefined
empty retimer msg same as clean retimer
retimer it's giving msg: --Unknown property: "controller" in undefined
please help
