Announcements
max 2020 custom toolbar missing scripts
grue1970
grue1970
hello. i have created 3 custom toolbars in previous version of max.  each toolbar had an icon i designated and when clicked on, it would execute a script.  for example, one button executed a random-z rotation.  another button random scale, another flatten spline.
i have the scripts saved in a network folder.
i just installed max 2020 and loaded my toolbars, but the buttons are greyed out with the message "Missing:scriptname"
how can i reattach the script to those buttons, and prevent this from happening in future upgrades?  or re-installs?
thanks!
3ds Max all versions past and present | GPU Rendering on 2 machines | Standard, MentalRay, MentalRay IRAY, IRAY+, VRAY, Arnold
thanks!
You will need to copy your (macro)-scripts to the location as defined in:
Main Menu > Customize > Configure System Paths > Additional Macros
Or simply dropping them in the 3dsmax viewport should work also.
Begging 3dsmax dev team to build a UI-Migration functionality might also work. 😉
grue1970
drat. it didn't work.  i copied them all over and restarted max.  oh well. back to drag-n-drop again.
same old same old - max ui
