Hi, does anyone have any idea how to fix this crap: https://www.youtube.com/watch?v=4DVZb1KJoLg ?
It's newly introduced bug/feature of Max 2015. Disabling adaptive degradation does not help. Nor does disabling any sort of antialiasing. Going to legacy D3D driver is not an option because it performs way worse than nitrous.
I suspect a problem with your graphic card or your drivers.
On this link you can see that your graphic card is not compatible, but not means it shouldn't work correctly. You could try a new driver or an older one.
Is it possible that you have this problem only with this scene and other big scenes, probably you won't have this problem with a single cube in the scene? On my 3ds Max 2015, i just tried with 2 massive scenes and i don't have that kind of problem.
Are you using a special device, for example a tablet or 3d mouse, i saw some problems in the past when these devices where not fully updated with the latest drivers.
And of course, make sure you have all available updates installed for 3ds Max.
Ok, probably the size of your scene that cause this problem, i would suspect that your video card is not enterly capable of dealing with massive 3d scenes. If you can try your scene with a high-end graphic card like the Quadro K4000 for example, could be a good test. I also have some minor glitch with my Geforce GTX 570.
A, K4000 is a lot lower end than GTX680
B, This wasn't the problem with Max 2014. It's introduced in Max 2015.
C, Performance-wise, scenes run just fine. This one particular has 13M of unique polygons, yet it runs at 60+ FPS.
Do you have desktop composition enabled ? ( windows setting, essentially the Aero thingy )
I seem to remember posts saying that having it enabled may introduce various viewport problems
Personnaly i would go with the GeForce GTX680, it is the great debate if Quadro cards are really better than Geforce for CAD applications. Quadro cards are supposed to be optimized for our 3d apps, but i am not sure this is advantageous when comparing prices.
Anyway, i was just suggesting to try another video card to see the difference.
I too have experienced this glitch from time to time. The geometry just loses its visibility, but is still selectable.
Another way I've found to invoke it is to use the link tool.
It's not always consistent though; sometimes it glitches, sometimes not.
Sorry. No. We have the same at work: Nvidia Titan cards.
Like Rawalanche said: 2014 ok, 2015 not ok.
And I dont use windows aero, i use the primitive windows graphics.
We've been dealing with it for some time.
Rawalanche: when the objects dissapears, it doesn't have to happen through rectangular selection, we simply have it when selecting objects around the scene as well. Giving it a few seconds reloads the ghost objects back in to life. (no need to pan or move the view to force reload them, max just reloads them automaticaly, only it can take some seconds)
Our scenes are heavy though. No doubt there. Should that be a reason though?
Dont know why. (we also don't use adaptive degradation so can't be that either)
grts
Yes, ineed, it's still selectable, just invisible. It's pretty annoying when doing precise selections, so that you have to stop the rectangular selection before you select more than you needed. It is also very random, sometimes just moving perspective view to different angle helps. And indeed, link tool seems to trigger it even more often than usual.
Someone can zip and attach a scene where you have this problem?
I would be curious to try it, i just tried many things and big scenes but i wasn't able to reproduce this problem.
i would be curious too for a repro scene
i do not work in Max 2015 that much ( still rely on 2014 mainly ) and would like the check this out
( i got a Nvidia EVGA 780GTX/ 6GB just for reference)
I´m experiencing the same glitch with max 2015. Objects disappear when selecting in orthogonal view in any of the normal views (i.e., front, back, right, left). Objects do not disappear when selecting if the gizmo is rotated at any other angle. Strange.
