I upgraded a few models to Max 2020 and all my materials are stacked on top of each other. I had everything nice and neat in my old file and now I have to drag the materials away from other ones, then whatever I have leashed into it I have to move out of the way as well. There are a lot of materials and will probably take me a week just to clean up the materials in the editor again for the 5 models I upgraded. I have to upgrade a few more models as well since I no longer have the older version of Max and I am sure will have to fix the materials for those models as well. Is there a faster way to separate them out again? Why do the materials come in that way after an upgrade anyway? It is silly that it does that.
Thanks.
Solved by 10DSpace. Go to Solution.
The 2 tools you may find helpful in your situation are "Lay out all" available from View Menu in the Slate Material Editor (Hotkey is "L") which distributes all of the material in the view vertically so that they do not overlap and "Lay Out Children" (also available in view menu; Hotkey = C) which lays out the bitmaps plugged into the individual slots of any selected materials.
