Material Properties Mass Editor - the professional tool for batch editing of material properties in 3ds Max
maxtoolsQUR5M
Message 1 of 1
maxtoolsQUR5M
Material Properties Mass Editor (MPME) is the professional tool for batch editing of material properties in 3ds Max. Allows you to modify properties across multiple materials of the same type, including native 3ds Max materials and third-party render engine materials (V-Ray, Corona, Arnold, FStorm, Redshift etc.), and any other installed material types. Changes can be applied according to the chosen scope: entire scene (including Material Editor and SME), selected objects, or selected SME nodes. The script implements a preset system that allows you to save custom property sets as presets for later use, streamlining workflow across different projects and render setups.
Main features
  • Batch editing of properties across all materials of the same type in the scene.
  • Support for any installed material types (classes).
  • Flexible scope selection: entire scene, selected objects, or nodes in the Slate Material Editor.
  • Recursive processing of materials located inside multi-materials
  • Clear visual feedback for all modifications made.
  • Powerful and intuitive preset system based on XML structure.
  • Preview all changes before applying them to the scene materials.
  • Automatic intelligent validation of input values depending on the property class.
  • Option to create a backup of the scene file before applying changes.
You can read more details here: https://www.scriptspot.com/3ds-max/scripts/material-properties-mass-editor
or here: https://maxtools.3dzver.com/product?id=2
Replies (0)
