3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Making a box follow the height of a cylinder
1 REPLY 1
223 Views, 1 Reply
Hello!
I'm quite new with 3ds Max and I'm trying to figure out if it would be the right program for my thesis.
I'm trying to model a ceiling mounted arm system with the possibility to change arm lengths and angles.
My problem:
I have a box with a cylinder attached to it. No problems there. Then I have another box which is the first arm of the system. I want the arm to move when I change the length of the cylinder so that the arm is always connected to the cylinder and the cylinder always connected to the other box.
How can I do this?
1 REPLY 1
grue1970
not exactly sure what you are going for but have a look at ALL of these: http://area.autodesk.com/louis_tutorials/animation_and_rigging_techniques_for_architecture_visualiza...
3ds Max all versions past and present | GPU Rendering on 2 machines | Standard, MentalRay, MentalRay IRAY, IRAY+, VRAY, Arnold
