Losing material When Converting FBX to 3DS in 3D Max
Message 1 of 8
我把FBX文件导入3D Max软件后,场景中模型具有材质贴图,此时我再次在软件中使用文件导出功能,把文件导出为*.3ds格式。导出过程中有如下警告。
此时找到3DS文件,当我把3DS文件载入到另外的软件面板中时,3DS模型丢失材质贴图,
我又把材质贴图修改名称,放入3DS文件目录下,发现载入后的3DS模型会有贴图位置不对的情况产生,或者依然没有贴图。
Replies (7)
Message 2 of 8
brentscannell
Hi @Anonymous
This should be somewhat expected, as the .3ds format does not support composite or procedural maps or materials other than 'standard' materials. What is the end goal of your workflow? Maybe we can find a different way to get there?
Message 3 of 8
I am using 3ds max 2018.FBX Plug-in version: 2018.1 Release (245710).
Workflow1:
I first export fbx from infraworks. Then FBX is imported into 3ds max, the scence looks like:
scene in maxscene in max
then in file menu, when exported to .3ds, it says
it says will preserve coordinateit says will preserve coordinateand shortened my texture filenameand shortened my texture filename
Butthere is no file[5_1_00.E.jpg] found where the .3ds file is.
When I open the .3ds file , it has no texture. the model is white, see the following picture
workflow1-outcomeworkflow1-outcome
Workflow2:
Continue with workflow1.
I found the texture bitmap file with the long name in the .fbm folder, moved it where the .3ds file is, and renamed it as 5_1_00.E.jpg .
When I opened the .3ds file again, it has the texture but with wrong coordinate
workflow2-outcomeworkflow2-outcome
My question is , where is the so called  5_1_00.E.jpg texture file exported to? And where is the preserved texture coordinate?
I am using a software which only recognizes .3ds file as the 3d model.
Message 4 of 8
brentscannell
Thanks for the clarification!
The image files do not get re-exported when exporting the model in .3ds format, the message you see is just an indication that the path that the model uses has been truncated, so your workflow to rename the image files before re-importing seems like it would do the trick.
Now, as for UVs, this is a more difficult one to diagnose. How does it look if you re-import the .3ds into 3ds Max? I've done a few quick tests with 3ds Max 2017, 2018, and 2019 and in all cases, UV coordinates where successfully exported and re-imported. I wonder if the software you are using to import the .3ds files is failing to import the UV coordinates...
Message 5 of 8
THANK YOU! You remind me of the  right thing.  I re-imported 3DS into MAX,it's white and I could not even be able to assign  the material . I think I failed to export the UV.
Message 6 of 8
hagen.deloss
Hi @Anonymous
I would check to see what UVW coordinates are on your imported object, I encountered an issue with .CAE files that reversed the UV in one axis to be minus instead of positive. Worth checking out if you haven't found the case of this issue.
Looking forward to seeing the solution to your issue 😄
Please select the Accept as Solution button if a post solves your issue or answers your question.
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 7 of 8
hagen.deloss
Hi @Anonymous
I wanted to check back and see if a post helped you with your problem. It would be super helpful if you could add a post with how you decide to proceed, and your results. That way other Community members can benefit from your process 😄
Hagen Deloss
Message 8 of 8
The problem still exist.  I now doubt whether the version of the software matters. I will post again when I check it out.
