Loop Tools: Circle, misbehaving?
478NWSu
I was under the impression that the "circle" tool in Loop Tools would work the same as Circle / Regularize in other software, but I can't figure out what it's actually trying to do here. The results are always a random mess.
Can someone please explain what I'm going wrong here? or if this is a bug? (using 2021.3)
RobH2
Unfortunately, not all softwares support the exact functionality for similarly named tools. Here's a link that shows the 'Circle' tool (skip to 3:45 if you want). I hope this helps.
https://www.youtube.com/watch?v=KXwBMaJOwEo&ab_channel=3dmotiveHD
Rob Holmes
3ds Max (2025-2027), V-Ray 7, Ryzen 9 9950X3D Processor, DDR5 128MB, Gigabyte Aorus X870E Master motherboard, Sabrent Rocket NVMe Gen5 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
I see, it seems that Loop Tools can only circle edges where there's an inset around them:
However, using RapidTools with the regularize function, you can turn any selection into a circle, with or without inset:
I hope Autodesk updates Loop Tools
RobH2
That's right. Looks like you have it figured out now. It's a useful tool.
Rob Holmes
Kranos_Orphydian
I've made a robust, detailed and well-illustrated idea on a similar tool implementation as of that of Maya and some scripts (so that others dont have to...) so might worth checking it on the ideas board and maybe vote it
[Circularize Tool] A versatile, competitive and well-integrated solution to rearrange selections int...
