Civil view object - traffic signs not rendering
svennib
svennib
Hi, I'm using ART renderer in 3ds max 2021 and are trying to use civil view traffic signs but they are not rendering with maps, looks fine if I use Arnold but I need it to work with ART. Pls help!
Libei.Wang
Hello @svennib ,
Thank you for reaching out to us.
I did some tests and couldn't repro the issue.  Can you share your 3ds Max scene with us to debug it?
Best regards,
Libei
Libei Wang
Sr QA Analyst for 3ds Max
svennib
Hi - and thanks for viewing this issue.
Attached is a 3ds max file along with two picture samples. As seen in the pictures, there is no texture on the light pole, the traffic sign and the rail when I use ART Renderer
Libei.Wang
Hello @svennib ,
Thank you for the Max scene and the screenshots.
I see that you have double-sided materials.  These are not supported by ART renderer.  That's why you saw the difference between ART and Arnold.  You can either change the double-sided materials or use Arnold as renderer.  I'd like to hear more from you about why you choose ART.
Best regards,
Libei
Libei Wang
