loft question
loft question
loft question
Can anyone tell me why loft never works right the first time? Why do i always have to untwist it?
I cant even un-twist this one.
miledrizk
Well you can un-twist it, by selecting the original shape, and going to its sub-object levels,
There you can play around with the vertices and segments while seeing the Loft object
Updating in real time.
miledrizk@gmail.com
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
Thanks @miledrizk I like that method better then using the twist  deformation.
iadproductions
Markr,
Before you create your loft object you can check the vertex positions of your shapes, you want your #1 vertex for each shape to line up as best as possible.  If they don't you can reset which is the #1 vertex, with the Make First button on the \Editable Spine\Geometry rollout.
Mastering Autodesk 3ds Max 2013
http://www.amazon.com/Mastering-Autodesk-3ds-Max-2013/dp/1118129717/ref=zg_bs_4135_2
Thanks @iadproductions.
All these little tip help! Have a great day!
