Light dots Vray
Light dots Vray
Hi guys!
Any ideas why the light on the ceiling is not smooth and why those random light dots in whole picture? The lights on the hanging lamp are Vray sphere, spotlights are Vray disc light, and by the curtains Vray plane. Rendering with Vray.
Best regards, Laura
darawork
There's a couple of tips here:
http://forums.cgarchitect.com/66470-white-splotches-vray-rendering.html#post334364
http://www.cg-blog.com/index.php/2012/10/22/splotches-vray.htm
http://forums.cgarchitect.com/71909-v-ray-gi-hdri-splotches-blotches-spots.html
Hopefully these will help.
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
miledrizk
It's not easy to guess without knowing the settings but we can try something:
Try to check the Sub-Pixel Mapping option in the Color Mapping rollout,
Also check clamp output, and try a test render and see the result. if you don't see
those two options click on the Default button to change it to Advanced.
Sub-Pixel mapping should be enough alone by the way.
Here i'm guessing that it's a matter of over bright areas that the image sampler(AntiAliasing)
Is not able to handle. I'm also assuming you're not using any caustics features.
miledrizk@gmail.com
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
Thank you very much, i tried out first two links and problem was solved! 🙂
