Layer manager desapeared
I have a good idea... I activate expert mode and hide layer manager. Now I can't see it back.
Any idea ?
3dsmax 2018 last SP win 7
No answer ?
Alfred.DeFlaminis
Hello @Anonymous,
EDIT: I removed my first post, I had written about the wrong issue.  My fault.
It may be that it's off screen currently.  This can happen if you're working with others and they have it off screen or something.  You can reset your user settings to get it back as one option.   Or, you might try to reverse the monitor order in case it's off on another monitor.  (Image below.)
Best Regards,
Hi, thanks for answer, but scene explorer is back now....
I don't know why, but it reappeared after installing a new script. It reappeared minimized at the top left of the screen (1 cm square).
So sorry if I can't test your solutions.
I'll delete expert mode in my key shorcuts !
Cheers
Alfred.DeFlaminis
I never even thought of that!  Thanks for the update @Anonymous.  Sometimes when I minimize windows I see them as small in the corner once in a while, I should have considered it.  Thanks again for posting your solution, that's great!
Best Regards,
Hi, again, "Expert mode" BOOM no more Layer manager window ( checked in menu  ) 3dsmax 2022.2 !!!!!
